M2Z went into auto land, all by itself
DVPOWERS
San Jose, CA
Hello All - My M2Z started to auto land all on its own. Batt was at 40%, flying over a lake and land, clear day, linked to plenty of satellites, Here is the link to the flight records. All help is very much appreciated.
Access to the google drive is locked.
OK ... so you shared your whole DJI flight records folder & left it to us to guess which flight it could have been that you experienced problems ... :oops:
Well, quickly scanned through all your flights & only found valid forcelandings when you was below 0,5m VPS height & kept on commanding negative throttle for further ascending.
One example below ... as you see from the bright green graph you where at 0,3m VPS height & by the blue graph, kept the throttle down enough long for the forcelanding to start (blue background color). This is how it works ... if this was your problem, it's normal.
Thanks for this. While I'm an experienced pilot, I don't have that much knowledge about flight records. This could solve my issue. I appreciate your contribution.
Reactions: slup
rodneyhinderliter826
