Just FYI, pilots with regards to the flight logs.
I received an interesting insight from DJI support team.
'The memory size for the flight controller data saved in the Mavic 2 is 1.5 GB. When the saved data reaches about 1.5 GB, new flight controller data will overlap the data written before'
Which means if you're flying regularly your past flight logs are overwritten.
