Hi there fellow countryman, welcome to the forum
You wasn't close to the bridge structure as seen on the 3D picture ... crash market with a red X, the log indicated a roll angle change from +4,3 degrees before & 156,3 degrees during the crash (also pitch & yaw shifted rapidly). The chart further below covers that within the red frame. The log indicates that both Obstacle Avoidance & Obstacle Avoidance RTH was inactive ... sure you had them activated?
Think they had some wire or perhaps cabling air-attached in that spot ... did you go there after the flight to look?
Might also add that keeping the drone within visual line of sight will make it easier & not so daring to fly ... & also within the laws & regulation.
**EDIT**
Now when you got the movie clip in place ... it's easy to see what you hit, not a mystery at all, this with log indicated Obstacle Avoidance not active.
