Mavic Air 2 lost
robinbanks
Sechelt, BC, Canada
So my Smart Controller crashed during RTH, and when I got a connection again all I got was a black screen and IMU error. :(
I'm heartbroken as my drone is my baby... Anyone had similar happen? I've stood on top of the GPS dot for last known coordinates and it's in the middle of a blackberry prickle bush field and I can't find it anywhere :(
Use the find my drone function , should show you a clear line to the drone. The IMU error could have been the crash itself.
Phantomrain.org
Gear to fly in the Rain.
Which again, is in a field full of natures barbed wire, though I've spent a fair amount of time whacking away with a machete and gathering countless injuries from the prickles I've not found anything there yet, and I've literally stood ON THE GPS PIN it gives me
Yes, please see: DJI Flight Log Viewer - PhantomHelp.com
FWIW when I go to "Profile" from the main screen of the Fly app and select "Locate my drone" it drops me a pin HERE (red X):View attachment 137656
The last recorded location isn't going to be where it ended up because it still had 14% battery and auto land was going to be triggered at 12%. So it will have travelled a bit further after you lost comms. That can be estimated by extrapolating battery level and position, indicating that it should have commenced auto land at 372 s, which is around 30 s after your controller crashed:
That suggests that it will have auto landed 1274 ft from the home point, with a margin of error of around ± 75 ft due to the 1% battery level resolution. Plotting that on Google Earth indicates the following location and circle of uncertainty:
I'll revise my earlier statement - that pin location looks like the SC reconnected with the aircraft after it rebooted, and it may be accurate if the aircraft started auto landing at the lowest end of the estimate - it's just short of my estimate. But it looks like it probably came down in those trees, not the field:
Yes, I did say that when I reconnected, all I got was darkness and IMU error, so are you saying it's at the pinned location somewhere? Where are those trees you sent a pic of?
A hint for Himalayan blackberries - use a couple pieces of 1/4" plywood to lay down over the vines - an easy way to make a path. A machete is a waste of time.
And - keep in mind any GPS fix has at least a 30 foot radius of uncertainty.
This might be a case to ask for other local drone owners if they'd come fly over the area to help look for your drone.
Reactions: Dbez1
Have you seen the price of lumber as of late? Also, the SAR mission has been so far handled by myself and I'm far from the big and burly type, manhandling sheets of plywood isn't exactly the type of activity I'm capable of alone
So given the margin of error in GPS signal, my drone is SOMEWHERE in this field of barbed wire, some of it up to 10ft in height, possibly in the trees at one side of it, but with my luck... :/
lol - that's why I mentioned 1/4 ply. $30 a sheet, and Home Depot will saw it down the middle. Easy enough to flip a half sheet around. But a 2' x 8' chunk of board is hard to fit in the average car, too. Owned 6 acres, half was blackberry fields, the rest where the blackberries wanted to be. We called the annual cut back our annual terra-forming project. So I understand your pain trying to bush whack into that field.
My 3D printer forum has a map of people nearby who are willing to help print things -- would be a great idea for this forum. And in other threads I've read of people volunteering. I love the Barbary Coast - sailed up to Desolation several times, so if I were closer I'd offer.
The error in the GPS signal is likely quite small - just a few meters at most. What are the exact coordinates that it is giving you now in the "Find My Drone" display?
Pilot KLB
