Mavic Air battery mod
I tried the Li ion battery but it noway better than LiPo or LiHv so I quit .
Dude I tried with 2 batteries. But the result is a battery value of 10% to 16 minutes. Where did I make a mistake? And did your dji air max give engine warning?
I'm not sure . Did you check both your battery remains ?
Remember to turn on the second battery first , then the battery on your drone .
I used two 1500mah external batteries. but the time showed 13-14 minutes and max motor speed reached. so i give up :(
I've had the same situation. Max motor speed and 16 min. Fly. Sorry it doesn't happen
some people make a 40 minute flight with spark :(
I don't want the range. I just want to increase the flight time
I did a lot of research. I tried it myself, but it didn't. I flew for a maximum of 16 minutes.
Oh guys , just 1 2400 mah LiHv from Mavic Air battery gave me 27 minutes ( even 28 when I over charged it to 13,35V ) .
Now, I get max motor speed warning when I plug the external battery to the mavic. Is this normal?
I think it's abnormal . Hover your drone and let it stay still , is it still waring ?
is this %0 not harmful for original battery?
I flew to lower than 0% for many times , not sure that will not harm the battery but everything still fine even nothing wrong with those battery .
Marlin
