- Joined
- Jan 22, 2017
- Messages
- 84
- Reactions
- 48
- Age
- 66
Here is what happened.
About the 6th flight of the day. Great weather. Was at 347 feet above takeoff point getting good everything. Was in sport mode. Getting a beautiful picture on my I-pad Mini. I was just over 2000 feet away in my rural neighborhood when I get an event message that says adjust antenna to avoid signal blockage. At almost exactly the same time the screen goes blank and the RC says LOSS of Signal. I checked my antenna position (just fine) and quickly changed my position. I waited a bit and touched return to home. Nothing, it just said Signal Lost.
I walked over to the position where it last reported. Nothing. Went back out after dark with a high powered light and GPS but nothing to be found. It is a wooded area. Will try again in the morning. I hoped that when I got home it would be setting there waiting for me but no such luck.
Do you guys think it is really there or did it fly off? It reported its last position and altitude of 347 feet. I had a good picture right until the end. Was way above the terrain.
Healthy Drone showed no problems other than a message that said Battery Overcurrent during discharge. I was running wide open when that happened so throttle back an it went out. This happened about 30 seconds before it was lost. I had lots of battery, only in the air about 3 minutes on full everything.
Any suggestions for finding it are appreciated.
