How many charges Can you get out of a Mavic mini battery
Where to you get your batteries? I'm still lookingI just got 2 extra MM batteries a week ago, dunno.
The MM has Lithium Ion batteries, and most other DJIs use Lithium Polymer.
Definitely follow up on proper battery care. Heat, and total discharge kills lithium batteries fast. Keeping them 100% charged can damage them as well.
Other DJI LiPO’s are intelligent, and slowly cycle a stored battery, and not let them totally discharge. Not sure if MM batteries need all that.
there is no set absolute charge cycle for any drone batteries,it is all down to how they are cared for during use,and storage, extreme heat will affect battery life as will cold to some extentHow many charges Can you get out of a Mavic mini battery
ok ty still no batteries hereI got them from a local dealer here in Saigon.
Does it mean that charging battery to 100% is a bad idea? Is it better letting it as it came from last flight and don’t charge it until next use?I just got 2 extra MM batteries a week ago, dunno.
@Moixixon because of the weather here in the UK ,it is very rare to be able to fly on two consecutive weeks, let alone two consecutive days, so because of this fact i only fly my batts down to 30% at most if i think i will be able to fly in a couple of days time, or 40% if the weather is going to be very unsettled for 5 days or more ,that way i know they will not come to harm, then i just charge them up the evening before i am going to fly again,if that doesn't happen then the fact that they are fully charged for a couple of days will not do them harm, i have auto discharge set for 3 days on my MPP, and as for the MM i just use the hub to discharge them, if i am not able to get airborne after 3 days by draining some power charging other devicesDoes it mean that charging battery to 100% is a bad idea? Is it better letting it as it came from last flight and don’t charge it until next use?
How do you use the hub to discharge the batteries ?@Moixixon because of the weather here in the UK ,it is very rare to be able to fly on two consecutive weeks, let alone two consecutive days, so because of this fact i only fly my batts down to 30% at most if i think i will be able to fly in a couple of days time, or 40% if the weather is going to be very unsettled for 5 days or more ,that way i know they will not come to harm, then i just charge them up the evening before i am going to fly again,if that doesn't happen then the fact that they are fully charged for a couple of days will not do them harm, i have auto discharge set for 3 days on my MPP, and as for the MM i just use the hub to discharge them, if i am not able to get airborne after 3 days by draining some power charging other devices
the hub has a USB outlet that you can use to charge other things like your phone ,so you can use it to discharge the batteries do it one at a time and just take them down till you get 2 solid lights and the third one flashing thats around 65% just do one at a time and keep an eye on themHow do you use the hub to discharge the batteries ?
Wow I've got so much to learn maybe one day I can give the advice![]()
Another hub feature, when you are charging, plug your controller into the output of the hub and when the batteries are charged, it charges your controller.the hub has a USB outlet that you can use to charge other things like your phone ,so you can use it to discharge the batteries do it one at a time and just take them down till you get 2 solid lights and the third one flashing thats around 65% just do one at a time and keep an eye on them
Thank you OMMthe hub has a USB outlet that you can use to charge other things like your phone ,so you can use it to discharge the batteries do it one at a time and just take them down till you get 2 solid lights and the third one flashing thats around 65% just do one at a time and keep an eye on them
That's a great tip thank youAnother hub feature, when you are charging, plug your controller into the output of the hub and when the batteries are charged, it charges your controller.
Thank youBetter to keep them at low charge for length of time than fully charged.
great tipAnother hub feature, when you are charging, plug your controller into the output of the hub and when the batteries are charged, it charges your controller.
One at a time.... sorryHow many charges Can you get out of a Mavic mini battery
@Xanadu what you are talking about is two different things, what @ToBAS was talking about ,was if you plug the full size USB cable into the charge hub and then the RCThat's a great tip! They have a picture of this in their documentation.
But they explicitly state that when using batteries as power banks, they shouldn't be connected to a charger. In another section they mention that the power bank function works only when not connected to a charger, strange...
