Mavic mini make only short (1.20min to 2.15min)videos ?
frendy
liverpool
Hello,my MM make only short videos up to 2.30min long and recording switch off, need to activate it manually.
How i can use camera throw the full flight ?
Thanks
I have that same card. Try reformatting it in the mini. I ended up replacing it with a Luxor Ultimate
I have that card and I can take videos lasting over 5+ minutes.
Definitely a U3/V30 card needed to be on the safe side. Not all cards of the same type have the same performance, so a U1 card can sometimes work sometimes not. There are differences manufacturer by manufacturer.
DJI have a list of recommended cards on their website. It must be U3 rated to be considered compatible, although some lower speed ones may work but there's no guarantee.
You could try switching to a lower video resolution and frame rate, but you're better off buying a card that meets DJI's compatibility criteria.
Reactions: frendy
engmarceloacs
