Mavic mini won’t link to remote after crash
agachpazha
Great Falls, Virginia
My Mavic mini hit pavement which broke the gimbal axis (replaced). After the crash I couldn’t turn it off and had to take out the battery. Now the remote and the MM don’t connect. I‘ve tried several times to re-link them without luck. I still have a problem turning the drone off with the power button. The following are the error messages. 30008, 30045, 30047 and 30049. Any help would be greatly appreciated.
** Code 30007 & 30008: No GPS signal. Unable to hover. Fly with caution
- Repair or replacement of the gps module is required.
** Code 30047: Barometer initialization failed. Restart aircraft
- Follow the instructions of the DJI.
** Code 30049: GPS Module Error. Restart Aircraft
- Restart the mavic mini. If it does not help, repair or replace the gps module.
From HowFixIT post All Mavic Mini Error Codes
It seems a hardware fault has intervened, could be a ZIF connector broken loose (there are blobs of glue on the sides) or some other board related problems (likely cracking of solder joints).
tyroe1998
