- Joined
- Jan 30, 2017
- Messages
- 47
- Reactions
- 34
- Age
- 28
So I got the Mavic fly more combo and wast getting ready to charge the batteries on the hub, when I noticed only one battery was charging. Does the hub only charge one battery at a time?
You can do that with this 3rd party battery charger.It would be better if it charged all three batteries at once.
So whats the point of it? It would be better if it charged all three batteries at once. Id rather have three individual single chargers where I could charge all three at once.
Apologies for my ignorance and inadvance of getting my mavic in the air, why would you set up a discharge time limit?Also something to note. You can setup the discharge time limit within the DJI GO 4 app. So say its set to 5 days. If you press the button on top of the battery it will reset the discharge time from the moment you press the power button. Essentially a reset of the timer.
Because leaving the batteries fully charged for more than a few days will shorten their life / could even cause them to swell. Think of the battery as a glass full of water... You want it as full as possible before you fly, as that will give you the maximum flight time, however, if you aren't going to fly then having the glass super full only means you are more likely to spill some which isn't good.Apologies for my ignorance and inadvance of getting my mavic in the air, why would you set up a discharge time limit?
Sent from my D6603 using MavicPilots mobile app
Thanks.Because leaving the batteries fully charged for more than a few days will shorten their life / could even cause them to swell. Think of the battery as a glass full of water... You want it as full as possible before you fly, as that will give you the maximum flight time, however, if you aren't going to fly then having the glass super full only means you are more likely to spill some which isn't good.
The purpose of the discharge circuitry is to (after a selectable number of days) drop the battery down to a safer level for long term storage (around half full is best for this type of storage)
Thanks.
So you'd let them drop to say 50% and let them drop charge naturally?
The battery will only discharge down to 65%. If that setting is set to 5 days, the discharge process will not start until 5 days have passed. At that point, it'll take an additional 2-3 days to discharge the battery down to 65%.In the GO App, you can configure the number of days to discharge. Over the number of days you choose (say 5) the cells will discharge down to about 50% on their own.
Thanks.
