I flew for the first time this year. Had to do it from my yard because Maryland is locked down due to Covid-19. I was really disappointed with the video I shot so I began doing a lot of reading. I decided to do a test at one of the settings that I found most common. I have a good environment to do a test in my back yard. You get bright sky as well as several objects that provide great detail to evaluate, like the brick, fence wood and trees.
Most commonly I found people recommending or using this: 4K @ 24fps / Shutter speed=50 (using ND) / Sharpness +1, Contrast -1 , Saturation -1
These is a lot of debate about Cinelike or DLog. So, I used the settings above and shot both and put them in one video side-by-side for comparison. Both have a typical LUT added but in the lower left corner of both I have an inset without the LUT. I did render it out at 1920x1080 so it wasn't so large but it is from 4K original footage.
Have a look at these and see if it helps you decide which is better. I prefer the shadow detail from the Cinelike. I was also very impressed with the lack of chromatic aberration around the small twigs against the bright sky. With my DSLRs (Canon 7D and 5D) I always get tremendous purples and blues around twigs in the sky. Impressive for the Mavic.
I hope this is useful.
drive.google.com
Screengrab preview:
Mavic Pro_Settings Test[Cine-V-DLog_+1-1-1]_05-03-20.mp4
drive.google.com
Screengrab preview:
