Mavic will not travel more than 30 meters away.
joekulis
Glenwillow, Ohio
Not in Beginners mode, but can not get the drone to go higher or further than 30m. Says I have reached maximum height and distance.
Correct. When you updated your firmware there was a message that stated your flight would be limited until you logged into your account.
I tried it, unlogged, and then logged in, same problem. Really confused.
The next step will be to roll back your FW & quit updating. Use the DJI assistant to do it.
Here is one video but there are others on you tube.
Reactions: Kman21
Try reinstalling DJI GO.
I think this is next too, and / or reinstalling the firmware.
The 30m thing almost guaranteed has to do with logging in. Even if you are logged in, or think you are, it seems the Mavic (or the app) disagree. Uninstall / reinstall seems to be the next step.
Also - check your settings again to be 100% certain that limit didn't make its way in there.
osje
