Mavic2 pro + Crystalsky 5.5 problem
Manual mode: can’t use + or - EV on 5D button for changing shutter speed
They are well programmed with the Crystalsky but don’t work In down-up or left-right
Hear sound but no change in shutter speed
Changing diaphragm works when programmed
And:
Changing shutter speed works from menu
Works also with connected iPhone
Did anyone encounter the same problem ?
Friendly greetings
A side topic, interested to know if you have cold tested it? Because iphone shuts down when 5 degrees of wind is blowing at it
Edward,
Did you find an answer to the 5D button on the CS. I too am having the same issue, not much help from DJI support, to date. It works beautifully on my iPad/IOS device. But not the Crystal Sky. All firmware is updated, DJI Go 4, Controller & M2Pro as of yesterday. I would like to know how to adjust the shutter in manual mode by using any method other than the screen. Thanks.
Best Regards.
rodolforeaper
