Unfortunately, batteries with this type of chemistry are like small children. More attention is needed.
There are several things, that over the years and my experience with this type of battery allow me to use them for a very long time.
Batteries do not like fast charging and rapid discharge, as well as high temperatures. Basically.
Some of the things that are important are in the second link from "tstr14's" post.
Additionally:
1. When I fly, I always calculate the flight time so that I land with about 5-10% battery charge. When I get home I discharge the battery slowly (relatively) to 0% or when the BMS disconnects the battery terminals. I usually do this slow discharge through a battery hub, in powerbank mode, charging something.
2. After the battery is depleted, I wait about 15-30 min and charge it with about 0.5C (500mA-1A) to about 50-55% and store it at room temperature.
3. Before flying, I always let the drone idle the engines for about 10 seconds.
In AliExpress, there are several types of chargers that give information about the state of the battery. Charge current, residual charge, etc. There is no mystery in DJI chargers. Whether theirs or another manufacturer's will be used is the same, as long as the charge current is not exceeded.
If we want the batteries to last longer and reliably, it is not bad to invest a small amount for these gadgets.
edit:
I forgot to add that I check the charge level every 10-15 days or so, via one of the Chinese gadgets.
For Dji Mini 2/se Qc3.0 Fast Charger Battery Usb Charging With Type C Cable Led Charger For Dji Mavic Mini 2 Drone Accessories - Camera Drones - AliExpress
