Cool. So, what's the dilemma then? It sounds like you already know which model will meet your unique needs.I know the difference between models, I've done my homework.
What is OA?
I will start by saying I have 4 Drones now; I would highly suggest you buy a small, cheap DJI drone and fly every day because once you feel comfortable flying drones, and if you are a photographer, you will go out and buy the best one available 2 to 3 months in a good luck
Regardless of which you choose, be aware of the RID compliance requirement which occurs in September this year. If your selection doesn’t include integrated RID capability, an add on RID module will be required, equating to additional cost.
This info is incomplete.Regardless of which you choose, be aware of the RID compliance requirement which occurs in September this year. If your selection doesn’t include integrated RID capability, an add on RID module will be required, equating to additional cost.
My starter drone, Mini 2, will require the module. After nearly two years flying it with great results, I’m seriously considering the Mini 3 Pro, which has internal RID and obstacle avoidance.
Above quote from:FAA said:Which Drone Pilots Must Comply With the Rule?
All drone pilots required to register their UAS must operate their aircraft in accordance with the final rule on remote ID beginning September 16, 2023, which gives drone owners sufficient time to upgrade their aircraft.
(emphasis added)
Good point re Recreational use.This info is incomplete.
A Mini 1, 2, or 3 (3 with standard battery) is under 250g / .55Lb, so for recreational use does not need to be registered. A rec-use drone that does not need to be be registered does not need RID.
Those flying non-rec will need to have each drone registered, and RID as of Sept. 16 2023, whether via native capabilities or a Broadcast Module one velcros, rubber bands, or epoxies to their drone.
Above quote from:
UAS Remote Identification | Federal Aviation Administration
Drones or unmanned aircraft systems (UAS) are fundamentally changing aviation, and the FAA is committed to working to fully integrate drones into the National Airspace System (NAS). Safety and security are top priorities for the FAA and remote identification (remote ID) of drones is crucial to...www.faa.gov
