Mini 2 won't connect via USB
Drone owner
UK
Has anyone successfully connected Mini 2 aircraft to the Mac with M1 processor and Big Sur installed? I won't see it in System Report as device connected to USB, nor in Finder / Disk Utility. Sure I tried few cables and two different computers. I am connecting the aircraft when turned on, blinking yellow. Any idea what to try? My goal is to download the videos and photos from the drone directly without removing the SD card.
@Drone owner ,if you do it that way it means the drone is powered on without cooling air going over it and it could become too hot, if you must do it that way at least have a fan blowing over it during the process ,it is much easier to put the SD card into a reader that plugs into one of the USBs on you computer
Mav_25
