Mini 3 Pro USB / Power bank charging?
linuxya
Antarctica
I'm curious if the new Mini 3 Pro 2453mAh and the "Intelligent Flight Battery Plus" still can be charged with a USB powerbank?
Charge on the go is big deal for me, traveling etc. When battery is depleted, I can use my SLR camera to take photos while charging the DJI battery.
2453mAh = 34 minutes flight time
Intelligent Flight Battery Plus = 47 minutes flight time
Reactions: Torque
I don't see any reason why not. It's still the same voltage.
Reactions: KLRSKIR
Has to work thru the cig lighter or vehicle power outlet to get required usb amps. Then it will work. Otherwise need an Ac/Dc inverter to standard charger.
Anyone can verify this?
The power charger station, normal battery & plus battery, can be charged through USB/powerbank/etc?
Reactions: Torque
Yes, it can. Read the manual.
The only option to power the hub is VIA USB-C. The hub works on USB-C PD up to 5v3A, 9v3A, or 12v3A based on what your brink or power bank is capable of. If you only have an 18w charger, it will charge at 18w (9v@2A).
Reactions: Torque
Neither the drone, nor the RC, nor charging hub know when it's connected to a power bank. As long as it's getting a wattage it's compatible with, it charges safely and as normal. You don't even need a PD charger, it will just charge slower.
All this is clearly laid out in the manual.
Reactions: Cymru
Yes.
Literally anything supporting USB-C PD over 30w will work.
Doesn't matter if that's a power bank, mains unit or a car 12v implementation.
The manual makes this clear.
Reactions: Skybuyer
DanCan
