I haven't compared them but I accidentally installed Master Airscrew props for a Mini 3 on my Mini 4 pro. I guess I didn't pay enough attention when I ordered
It does fly without issues
The blades of the mini 3 and Mini 3 pro and Mini 4 pro are, as far as I know, identical.Sorry did you install Mini 3 propellers or Mini 3 Pro propellers?
Ok for the latter, not ok for the former.
DJI Mini 3 Pro / 4 Pro STEALTH Upgrade Propellers - x4 Red
Upgrading your drone has never been easier! Simply swap the props of your DJI Mini 3 Pro.www.masterairscrew.com
That's a surprise, any problem with the cross slot rounding out or the screw head shearing off?The Mini 4 Pro screw has no shoulder and I didn't use the screws from Master Aircrew or I would have noticed that.
The Master Airscrew ads don't show the screws that are included but DJI ads do
Not yet, seems I should be using a ph000 bit from my electronics repair kit rather than the supplied screwdriver on those screws as some users seem to strip the phillips headThat a surprise, any problem with the cross slot rounding out or the screw head shearing off?
I use Mini 3 propellers on Mini 2. Previously I used Mini 2 engines, now I have installed Air1 engines. In any case, Mini 3 propellers are preferable.@Yorkshire_Pud its not possible to use the Mini 3 props on the Mini 2 why ,because of design of the arms of the Mini 2 ,are different to those of the Mini 3 varients and the props contact the body...
I don't know what drone those propellers are from but they are NOT from a mini 3.
Propellers from Mini 3. Central hub from Spark. To install propellers on Air1 engines. You wrote about the impossibility of installation, I clarify that it is possible. If the hands grow from the right place.I don't know what drone those propellers are from but they are NOT from a mini 3.
All "Mini" propellers are supplied as a pair of loose blades unconnected to each other via a central hub.
Yes. The hovering flight time increased by two minutes, all conditions being equal. 3500 mAh battery on Mini2 propellers and engines was 38 minutes, on Mini 2 engines and Mini 3 propellers it was 40.5 minutes.
