Multi battery charger not working
Did you plug the normal battery charger into the hub? The only time I've seen the red light is if I plug the hub in through micro usb
Plug the other cable into the bottom. Looks like you have the controller charger cable plugged into the charger.
Correct...the USB Micro port on the side of the hub is for firmware updates when available
tflys78
