Welcome from the Hampton Roads area of Virginia, USA. I fly a
Mini 2 and I know the excitement you are going through…
You are living a whole new part of the world, be sure you are following all of the laws and rules applicable to you. Here is a DJI Link to Many Sites of interest to all, even those in the U.S.A.
Drone Flight Application Strategy Digest, continually updated!
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro. You will also find the 74-page
Mini 3 Pro's User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Mini 3 Pro - Downloads - DJI
Happy and Safe Droning…
