New firmware: V01.03.0600
Upgrade went through easily and after several flights I can't find any faults in the new firmware yet. All is good.
Are you recording video normally to your Mini 4? My mini was hit by the failure to cache videos bug and I have tried reflashing .600. Rolling back to DJI Go4 v4.06, downflashing to firmware .400 then .550 and still no video. Going to see if there is a complete reset option and try that next
I have tried upgrading to .600 but have failed each time. I have tried both via app on my iPad and directly from Mac and it fails to install (uploading and transmitting ok). I am currently on .500 so I am wondering if I need to upgrade to .550 first and then .600? Or could it be that the cached download is corrupt?
You should be able to jump straight to .600. While doing multiple flashes today to try and resolve a problem I was able to do that.
For those who have trouble to uograde - I had the same problem upgrading from .3 to .4. Tried everything but always stucked around 7x% in dji go or around 5x assistant (not sure if I remember correctly). Once it stucks (so it does nothing) just restart only the mavic (and only). The upgrade will continue.
So do this before it automatically restarts?
Odd one out here it seems, but my .0600 updated smoothly, flies rock solid, gimbal is fine... I enjoy the occasional flight on fixed wing just for the effect of cruising over waves at the ocean. :-)
Reactions: Michael Ainsworth
I don't get the purpose of FixWing mode. I get how it works but Can someone please let me know when you would use it?
When you want your drone to handle like an airplane in FPV mode. More of a fun thing than for doing videos.
While I had issues getting 600 to install I'm very happy with it, no know issues found to date after several days use
Yeah it's odd, I don't know if it's part of the the startup gimbal process now??? I did do a gimbal calibration and that was a much longer process and it said calibrated complete and looked good, so Not sure if it just from the update. However when i started flying everything seems fine and worked well.
Have the startup gimbalance tilt gone away?
I have done all the updates from 400 to 600 and never had a problem. I won't say this will cure all problems nor am i telling you what to do, just sharing my procedure.
1. Update mavic then controller.
2. recalibrate rc.
3. After letting mavic cool down (off) i do the IMU recal, preferably within 2 minutes then switch off.
4. Restart, calibrate gimbal inc manually tweaking the horizon using 2 perfectly level work tops parallel to each other.
5. Redo my preferred settings including resetting cam ntsc to pal and back.
6. Calibrate compass.
Hope that may help.
After upgrade in sport mode total crawling not the 46.6mph Ive seen before, odd.
You have to reenable the multiple modes. It defaults back to "no" which only allows P mode in either switch position or whatever it is.
Reactions: Rbruz
tested after updated to .0600. I experienced altitude lost for about 1m when it was at 20m hovering. then also experienced the RTH not precise landing. all setting including precision landing was on. Sometimes "gps erorr" pop up on screen. .0550 was more stable.
I'm having issues with my Gimbil with .0600, where the camera is not level. Tried recalibrating and nothing. I didn't see these issues on other firmware versions. I'm going back to.O400 as well.
I'm having issues with my Gimbil with .0600, where the camera is not level. Tried recalibrating and nothing. I didn't see these issues on other firmware versions. I'm going back to_O400 as well.
You can manually adjust it, i have always had to fine tweak mine on all FW versions.
I'm planning to revert back to .550 from .600. I'm annoyed of the occasional gimbal issue. So to revert I need to use DJI Assistant 2 is that correct? What about for the controller?
Yes, use the assistant for both.
What gimbal issue did you have?
After the upgrade to .600, did a couple of flights that were good. Yesterday morning, started her up and gimbal started at about 30 degrees...took about a min before it corrected itself. Then while in flight when I would fly to the left or right, the gimbal would not stay horizontal. There has been a report of this happening to others in another thread I started.
Ok, not had that in the 6 or 7 flights on 600 fw.
Hope it sorts it for you :)
Reactions: Rplanas
updated and flew .600 today, everything seemed good except i took a few bracketed photos and there is no difference in all 3 of each shot...ive used this many times with no issue.
mariovaleo
