New member.
Welcome to the forum! :)
Welcome to the forum. We look forward to your participation and your view of the world.
New member her(e) from Arizona.
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
In your other posting, you wrote that you have an Air 3 and a Mini 3 Pro
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . Your Air 3 Drone weighs more than 250-grams (0.55 pounds) and while you are flying under The Exception for Recreational Flyers, you are required to register your Drone. Registering your M3P is optional but can be added to the Rec Account at no extra charge…
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Arizona, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below are the links to all of the downloads offered by DJI for the Mavic Air 3 and the M2P, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Fly On and Fly Safe…
Welcome to the forum from Chicago the Windy City.
FLY SAFE & FLY SMART ALSO FLY LEGALLY!
Reactions: LoudThunder
aodgizmo
