New Pilot from Canada
Zetec7
Sooke, BC, Canada
Hello, all. I'm a new member from Sooke, BC Canada.
I wanted a small, high-quality, very portable aircraft, so I bought a Mini 2 Fly More package (of course, a few weeks after I bought it, the Mini 3 came out).
So far, I'm loving it. We're moving out of the country, need to sell our home, so some drone footage for the listing seemed like a great idea....and I had the Mini 2, so I figured "How hard can it be?" Well, it was a lot harder than I thought, that's for sure! My property is over an acre, and is populated by 150' cedar and fir trees, with not much open area. That makes it a lot more challenging for a brand-new pilot (never flown a drone before). So, it's learn-as-I-go. I used to fly fixed-wing RC airplanes, and still have the muscle memory for that, which has caused me problems as the sticks on the Mini 2 have very different controls, but I'm learning.
I have noted a couple of issues, though, that I hope some here can shed some light on. Yesterday, I had the drone hovering about 6' up & 6' away from me when it suddenly ascended to about 20' & rotated 90 degrees, with no input from me. At that point I had absolutely zero control over it. Battery was at over 90%, GPS signal was solid, phone was at 95%, etc. I had also previously performed all the firmware updates as recommended (and subsequent flights were totally normal...until this one).
That was spooky!! After a minute or two, control returned (with no actions from me, as none seemed to be available) & all was normal again. Since I have to do some flying over water (ocean) tomorrow, I'm worried this might happen again.
Anyone have any experience with this, or suggestions on what to do if it does happen again?
My second issue is that when flying around and among trees & bushes, the drone drifts a lot - side to side & up and down - which makes it tricky when flying close to foliage. Is it possible that the GPS signal was weak with overhead bushes & allowed it to drift?
Thanks...
Hello from the Crossroads of America Zetec7.
If you follow the instructions below, it may be possible to extract the flight log from your device and see what could have happened.
The GPS could be compromised when flying low underneath foliage and the bottom VPS may not "see" the ground well, causing it to drift.
It's just a guess. 🤔
Welcome to the Forum. 😎
Hi Zetec,
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar.
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy, Safe and Legal Droning…
Reactions: Rotorfreak
Greetings from Birmingham Alabama, welcome to the forum!
Welcome to the forum! :)
Reactions: MA2 317 and GFields
Welcome to the forum. Sometimes it's hard to find the reason for such sudden weird movement. It could be the sensors if it's close to an object. However, normally it's safe to fly in an olen area, even above water. Use P or N mode to fly steady is another suggestion.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
You can change how the sticks behave in the DJI Fly app. Check and see if one of the other modes is closer to what you are used to, and maybe switch to that.
Thanks! So far I've been flying in Cine mode, because my very first, learning project is a crucial one - it's to showcase our home for sale on the MLS, Facebook, etc. Considering the environment (dozens of first growth 150' cedars, with many low-hanging boughs that I have to fly through, sometimes with only inches of clearance), it appears I chose a fairly ambitious project for learning on!
I'm getting there, though. I'm slowly learning to combine pitch, ascend/descend, yaw, forward/back and sldeslip all at the same time, which I need for various shots to satisfy my wife, who has taken on the role of director for the video!
By the way, I'm compiling all my videos and stills in Windows Movie Maker (still have it on my computer though it's no longer available) because it's easy, and I'm already familiar with it. Anyone have any suggestions as to an easy-to-learn, affordable (free?) video editor that I should consider?
Use the forum's search feature.
Welcome to Mavic Pilots!🙂Enjoy the forum!Thumbswayup
Hi Zetec,
Since he is flying a sub 250 gram drone a lot of rules don't apply to him but it is always smart to not do something stupid. Here is a great video explaining what a new pilot of a sub 250 drone should be doing.
Welcome to the forum and good luck selling your house.
It is a Good Video. I am in the US so I do not know how accurate his video presentation is but it is now over a year old. That is why when I posted the Link to the Canadian Drone Rules and Laws Web Site, I prefaced it with the warning, "Please check to ensure these are current."
As Canada's top instructors and were very much part of the formation of the new drone rules in Canada helping DOT and Nav. Canada form what we have now you can bet your bottom dollar the video is up to date.
dojin23
