New pilot here!
Florida
Hello! I’m a new pilot from florida, and I fly the Dji mini 2. I have the TRUST test certificate and I’m thinking of getting the part 107 certificate in the future. I also have a few questions. I’m going to Spain in a few days, and I’m thinking of bringing my mini 2. Are there any specific regulations I should be aware of? Will my drone be allowed on the plane? (Again, I’m a new pilot and have a lot of questions)
@Yaros is from Spain, he may be able to assist you.
Check with your airlines about carrying drones on board
I’m flying on British airways, I checked and it said a few restrictions but no major things
Most, if not all, airlines require you to store all batteries in a carry-on, not checked luggage.
Greetings, Hand Sanitizer, and welcome to our forum from the friendly skies of North Texas!
We have over 150,000 members worldwide (including many in Florida) who enjoy helping each other learn and grow as pilots and photographers. Anytime you have a question, just ask!
By all means, take your Mini 2 to Spain. I've taken mine on many air trip son various airlines. Never a problem. Never was asked to open the case, even when flying without TSA Pre. The most ANY airline might do is to ask that your batteries be transported in Li-Po safe bags. I carry one for each battery just in case. Never was asked to use them.
Have a great trip to Spain! Share your results!
Rich R (alias Hauptmann)
Alright thanks! I’ll be sure to share my photos and videos! (this is my first time flying at a beach since I’m going to the Canary Islands too!)
Since your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
When I first started flying I registered my Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Pilot.
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Florida, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Fly On and Fly Safe…
Yea I was thinking about adding my phone number. Also I already did all these things. I’ve flown it a few times and done a million range tests 😆
Put your information on the SD Card as a word document.
If you lose your aircraft and somebody found it years down the road, the information may still be intact on the card long after the stickers have worn out due to the elements of Mother Nature.
True but who’s gonna grab a drone and pop out the Sd card to see what it has? Plus I can always replace the stickers or engrave it on the drone
Pro-MBS
