That's not possible. The drone is only able to return to the current home point.
In DJI GO, you can manually set the home point to the aircraft's current location or the current location of your mobile device (if it contains a GPS receiver). See the screenshot below.
If your mobile device does not contain a GPS receiver, you can attach an external GPS receiver to it (like
one of these). You'll need to manually set the home point each time you move to a new location.
Thanks a lot for your reply, especially the screen shots which are very helpful. Until now I've been using an iPod Touch as my mobile device, which doesn't have GPS. However, I also have an iPad that is GPS capable, so hopefully that'll work. First I need to buy a longer Lightning cable, but may need a bit more guidance once I get it hooked up... hope you don't mind if I check back with you in a few days
Thanks!
