mavicpilots.com
The web site also has a Mavic Air Subforum…
mavicpilots.com
Also, if you have a Facebook presence, you might try the Indiana Drone Pilot Group…
Log into Facebook to start sharing and connecting with your friends, family, and people you know.
www.facebook.com
As a "Newish" Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs less than 250-grams (0.55 pounds), and while you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…). Your Drone weighs more than 250-grams (0.55 pounds), and even while you are flying under The Exception for Recreational Flyers, you are required to register your Drone.
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
faadronezone-access.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
30+ free and paid classes to fly your drone. Pass your FAA Part 107 license exam, learn how to fly your drone, and more.
pilotinstitute.com
Since you live in Indiana, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
44809 is an exemption from Part 107 drone laws. This means that drone pilots fly under Part 107 drone rules by default unless they meet all 9 of the requirements to fly under 44809, the exception for limited recreational operations of unmanned aircraft. You can read more about these requirements...
pilotinstitute.com
Lift off, 6- feet (2-meters) or so, hover a bit, check the controls (move the drone a bit forward, back, left, right, yaw left and right). By now, your Controller will probably report again, Home point Updated.
Below is the link to all of the downloads offered by DJI for the Air, including the User Manual.
Learn and download Mavic Air related apps, software, and manuals at the DJI Download Center
www.dji.com
Fly On and Fly Safe…
