NZ in Thailand via Dubai
Hello from the Crossroads of America Kiwiexpat.
Welcome to the Forum. :cool:
Welcome to the forum from the beautiful woods of Maine!
There’s many knowledgeable members willing to help you with any questions you have. Search the forum using key words and if you don’t find an answer, post your question and I’m sure you’ll get a quick response! Fly safe and stay safe!
Greetings from Birmingham Alabama, welcome to the forum!
Hi All, we are on our way from Dubai to Thailand. Born in NZ but lived most of my life in Dubai. Thailand for retirement and will be laarning to fly Mavic Air 2s. Looking forward to meeting some of you and swapping war stories.
Welcome to the forum from the mountains of Colorado! Happy and safe flying!
Welcome from the Hampton Roads area of Virginia, USA. I fly a Mini 2 and I know the excitement you are going through…
We have a Member's Map in the Upper Right of the Title Bar, Tap "Members", Tap "Member's Map" Members map
Here is a link to the Thai Drone rules and laws, be sure to check for recent changes…
Now, for some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Air 2S. You will also find the 57-page Air 2S's User Manual, in case your Drone did not come with one. The User Manuals are published in different languages.
DJI Air 2S - Download Center - DJI
Happy and Safe Droning…
Thanks so much. Am in members map and can’t see how to add my location. What am I missing?
Reactions: Skywatcher2001
That would be a question for @clackey, but last I heard the member's map is unreliable.
Touch your avatar at top right, Account details then scroll down.
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
I checked my location and it is exactly as I set it. As a retired computer programmer, I will fall back on a "tired old cliché" -- "Garbage In, Garbage Out…"
My guess would be that various members entered their city, county, providence, region, state, territory, country, continent, planet, etc… and the map software made a best guess to that "very unspecific" location and probably just centered the pointer in the middle of the region.
I seem to remember being given the option to adjust the pointer after it was positioned by my input…
Welcome to the forum! :)
JefScot
