Polarpro retractable landing gear...
If the rear legs are redesigned so breaking is less likely, will you be offering a swap to those who have the original/defective design?
Thanks for your question, Floyd. I can not confirm a redesign, though I will pass this along to the Support Team for future consideration should there be any change.
Reactions: Mavic Pro Platinum
Are these available again? If so and you bought them, has the design changed?
Hi Floyd! We are working hard to have these back in stock by the 26th of March with a few minor alterations. If you would like to put your order in now via the web store, the product will ship as soon as available!
Thanks for your continued support!
Messaged with Brendan today 3/18/2019..
Great to see the company is being proactive and fixing the poorly designed landing gear. I only wish I would have bought the newly designed gear a week later. Any plans to recall the defective versions?
Hi Floyd, If you are having issues with your landing gear, please do not hesitate to reach out to the support team here: Support
Thanks!
When the Mavic is folded and the gear is attached will it now fit into my DACCKIT case?
I just received a complete set to replace the rear leg that was broken. PolarPro quickly sent these out after I answered their questions about what happened.
Reactions: Thomas B
It looks like they’ve added a piece between the two halves that are used as a pin or rotator point.
Can you post pic of new design please
Is that the retractable ones or fixed?
Ok that’s good to hear. I’m still waiting on mine , guessing the holdup is due to the rejigging
If you use a DACCKIT case for your Mavic 2 Pro and have the newly redesigned PolarPro landing gear, will it now fit in the case without having to remove the landing gear? The old design will NOT allow the MP2 to fit in the DACCKIT case.
I'm guessing the lack of responses to my question means when the "redesigned" PolarPro landing gear is installed and retracted it WILL NOT fit in the DACCKIT case.
devonwalterslee
