I was wondering if anyone at the forum has used portable 2 way radios , also, the receiver to hear pilot communication that the courses mentioned. (1way only) receiving of course. What does the forum members highly recommend?
I was curious because it’s mentioned in the course I am taking. I guess there referring to having the ability to hear plane traffic if your in rural areas , around mountains, and such. What about 2 way radios? For use on commercial missions?I don't think it would be that useful unless you're going to be flying near the approach or departure end of a runway. Is that what you're planning to do? On the downwind leg, planes are usually 800' or higher, and even on crosswind or base leg they wouldn't normally be below 500' or so. It might be useful near a helipad in a metropolitan area, but I think even that's a stretch. People transiting through the area at altitudes low enough to be a factor aren't typically making calls in the blind announcing their position.
For you to communicate with others on your team? FRS radios would be good for that if you're not at a congested location like a ski resort. They are good up to maybe a half mile or so. For longer distances better quality GMRS radios are pretty good.What about 2 way radios? For use on commercial missions?
Pretty much any scanner will let you listen to pilots and the tower. Many of the police and fire organizations are switching to digital so these scanners aren't as popular as they once were, but aircraft radio is still analog and unencrypted, so you'll have no problem listening to their chatter.I was wondering if anyone at the forum has used portable 2 way radios , also, the receiver to hear pilot communication that the courses mentioned. (1way only) receiving of course. What does the forum members highly recommend?
Awesome info. ThxPretty much any scanner will let you listen to pilots and the tower. Many of the police and fire organizations are switching to digital so these scanners aren't as popular as they once were, but aircraft radio is still analog and unencrypted, so you'll have no problem listening to their chatter.
I still have my 30+ year-old Uniden Bearcat, and you can still buy a later-model version of this:
Uniden Bearcat BC125AT Handheld Scanner
I am not current on this technology so I have no idea whether this is the model to get, although Amazon does show it as the #1 best seller.
You can listen to approach and departure control when the planes are a long way out. They then get handed off to the local tower for the actual approach to the airport. Once on ground, they switch to ground control. Planes which are taxiing out to the runway to takeoff also use the ground control frequency.
So, if I were operating near an airport and wanted to know everything about planes that were coming and going, I'd enter the tower and ground control frequencies into one bank of the scanner and have it simply scan continuously through those two frequencies. I'd also find the approach charts for each runway, and learn how to know which one is being used that day. The approach plates will show you the recommended approach altitudes.
Just curious which course you are taking - I am getting ready to take a course to get my certificate.I was curious because it’s mentioned in the course I am taking. I guess there referring to having the ability to hear plane traffic if your in rural areas , around mountains, and such. What about 2 way radios? For use on commercial missions?
I have an aviation transceiver (an old Sporty’s SP-200) that I use as a backup while airplane flying, but have never bothered with it for drone flying. It would take luck to figure out what frequency any particular pilot was on (unless you are close to an airport and tune the CTAF). Anyone communicating with the local ARTCC would be flying well above the SUAS allowable heights. Also, unless something is changed recently, FCC rules do not allow transmissions without a license if you’re not actually in an airplane, but I think you were referring mostly to receiving abilities.I was wondering if anyone at the forum has used portable 2 way radios , also, the receiver to hear pilot communication that the courses mentioned. (1way only) receiving of course. What does the forum members highly recommend?
I was granted a Certificate of Authorization to fly up to 100’ (in a 0’ ceiling area in the UAS facilities map) in Class D airspace near my home in FL. In the application I wrote:Also, unless something is changed recently, FCC rules do not allow transmissions without a license if you’re not actually in an airplane, but I think you were referring mostly to receiving abilities.
I thought the 2 way radios were once required! I was thinking in B Airspace, but I can’t remember.
