Prop Guards
Chepstow, Monmouthshire
Bought myself a set of prop guards for my MP.
Does anyone actually use these and if so do they have any effect on performance when flying outdoors.
I don't think I'll use them for outdoor flying, but maybe indoors.
Credibility on the street = 0 (man! those things are hideous)
you could use them to hang your Mavic on the wall I suppose
[Edit] Performance wise I've no idea but doubt it since the force of flying isn't going in the direction of those things or they wouldn't have options in the app to toggle if you are going to use them.
Maybe they do affect flight in some way!
Reactions: Markjenkins5515
I use them on an inspection bird as I fly in tight places and around obstacles. When you turn on the prop cage feature in the go4 app it will change its flight characteristics and make it handle more sluggishly (for lack of a better description), not in a bad way though. Its slightly slower and stick input sensitivity is reduced.
If you remove the cages and forget to turn it off in the app the craft will shake violently when you try to take off.
Reactions: SpinItUp
Thanks for the advice, I probably won't use them.
Only got them as I used to put them on my P3P when flying indoors
I use pro guards when flying indoors. I do this to protect the walls and furniture.
ICantStopTheLoneliness
