Rookie question
Rossta
I’m pretty sure I know the answer but here goes.... I didn’t hit record on some amazing footage (ID10T error) and want to know if internal storage automatically got it.
Footage is not automatically recorded on the internal storage.
On the same note mavic 1 the app no longer saves video to phone anymore am I correct. Did when I first got it, had 4 or 5 updates since then.. i don't believe I'd changed anything.
If you have that feature turned off, then correct, it won't cache to your mobile. I don't recall if the default is on or off. Updates (both app and firmware) have a tendency to reset settings.
You can now even select to cache to an SD card installed on the mobile.
Set both cache and sd card can't get it to save to phone anymore was 2 or 3 updates ago even clear cache before flying. That was a great feature I know it saves to app you have to dl to phone which is a pain since I'll watch video when cooling. down.
Also, place a label on your tabby screen:
"Are you recording yet?"
I have not missed a shot since I did this...
LateParrot
