Thanks for the info. Confirms what I already thought I knew. The Emlid equip is almost as much as the M3E RTK.PPK kits are way too heavy for your little guy to carry in any meaningful way.
Are you sure you need RTK or PPK. You can make very nice relative accuracy maps and models that have use cases.
If you go the centimeter accurate route, you will need an RTK service or your own base to send corrections to your drone and will have to do some studying on datums, coordinate systems and projections to output quality data.
You could just buy a GNSS Base like an Emlid unit and lay and mark Ground Control Points. This is a proven way to introduce accuracy into photogrammetry. But just to dip your foot into it would be overkill. This GNSS Base would need RTK corrections from a service or be setup on a quality known point for absolute accuracy.
