Self contained locater Beacon
RallySoob
These are 35$ on Amazon which i feel is steep but after buying 1 i had to go back for 2 more. The power this little led puts out is beyond amazing. Its much smaller than you would think too. I can now see my mavic with ease at night . Fyi 1 is plenty i just want it extra bright
Ill load a video of it flying tonight. If you need a beacon try one of these
70mah lipo battery, micro usb port, has mini on/off button: push once to check battery life (1-3 blinks to show level) and gold down for 3 seconds to turn strobe on or off
Reactions: D700
Thanks for sharing. Seems to a good strob indeed, could when you have time post a video with it? I'm considering to buy one of these
They sell them for about$11 USD or 9lbs on Flatiron.com
Sorry flytron
UAS Drone DJI LED Green Strobe Light for Quadcopter RC Aircraft FAA Required for Navigation Fully Self Contained NO Wiring Needed DJI Inspire 1 Phantom Mavic Typhoon H Yuneec Amazon.com: UAS Drone DJI LED Green Strobe Light for Quadcopter RC Aircraft FAA Required for Navigation Fully Self Contained NO Wiring Needed DJI Inspire 1 Phantom Mavic Typhoon H Yuneec: Camera & Photo
The STROBON Cree would be a better fit for the Mavic since it's smaller.
Reactions: Soundtekk
Not a noticeable difference size wise, I have both couldn't wait for 2weeks to receive so I ordered the ones on Amazon for $35, now I wish I didn't order from Amazon and I shared the wrong exact link but it's the same website
Reactions: Techstar
Yeah, it's not too much different. The CREE version is only 2mm smaller on all sides. The larger version is available here. It's currently back-ordered.
I have white and red STROBON Cree strobe lights in stock. You can buy them from me here.
Reactions: Soundtekk and Dw911
I wrote them an email (flytron) somethingike 2 months ago.. never received an answer.. I wonder if their business is serious.. I really wanted to buy a couple of them
Just got 2 more from flytron, so they are still in business at least in Europe
Ender
how long will a full charge last?
The Cree version lasts 2+ hours (per the manufacturer). It takes 2 hours to recharge it when the battery is empty.
Checkout firehousetechnology.comthey have same idea runs 5hrs recharge in 2 hrs 3W LED comes in White, Red, Blue and Green
22mmx18mmx10mm
$29.99
FAA compliant dusk/dawn night
In Stock !
They also sell them here on Amazon. Or get them direct from Flytron for much less. They should do the job for most people, but they are larger, heavier, and not as bright as the Cree version.
Here's a comparison between the STROBON Standalone (linked above) and STROBON Cree models (the Cree is on the right):
Do they not have a flash setting ?
Was thinking of getting a couple of these -one on top and one underneath - more as a way of finding your mavic should you loose it.
Thinking if I did loose the mavic and couldnt find it, once it got dusk/dark something like this might make finding it easier especially if they were flashing.
Plus the flashing would pretty much double the battery run time
vbresults
