Depending on the camera manufacturer, video files can have EXIF entries.
Here an EXIFTOOL output from a Canon R camera:
ExifTool Version Number : 11.31
File Name : canon_eos_r_01.mp4
Directory : .
File Size : 1126 MB
File Modification Date/Time : 2019:11:15 04:04:14+01:00
File Access Date/Time : 2019:11:15 04:04:14+01:00
File Creation Date/Time : 2019:11:15 04:02:50+01:00
File Permissions : rw-rw-rw-
File Type : MP4
File Type Extension : mp4
MIME Type : video/mp4
Major Brand : MP4 v2 [ISO 14496-14]
Minor Version : 0.0.1
Compatible Brands : mp42, avc1, CAEP
Compressor Version : CanonMP4_002/09.00.00/01.00.02
Exif Byte Order : Little-endian (Intel, II)
Orientation : Horizontal (normal)
Resolution Unit : inches
Y Cb Cr Positioning : Co-sited
Exposure Time : 0
F Number : 4.0
Exposure Program : Aperture-priority AE
Sensitivity Type : Recommended Exposure Index
Recommended Exposure Index : 0
Exif Version : 0231
Date/Time Original : 2018:09:05 14:39:17
Offset Time : +01:00
Offset Time Original : +01:00
Offset Time Digitized : +01:00
Components Configuration : Y, Cb, Cr, -
Shutter Speed Value : 1
Aperture Value : 4.0
Exposure Compensation : 0
Metering Mode : Center-weighted average
Flash : No Flash
Focal Length : 24.0 mm
Macro Mode : Normal
Self Timer : Off
Quality : Movie (2)
Canon Flash Mode : n/a
Continuous Drive : Movie
Focus Mode : Movie Servo AF
Record Mode : MP4
Canon Image Size : Unknown (136)
Easy Mode : Manual
Digital Zoom : None
Contrast : Normal
Saturation : Normal
Camera ISO : Auto
Focus Range : Auto
Canon Exposure Mode : Aperture-priority AE
Lens Type : Canon RF 35mm F1.8 Macro IS STM or other Canon RF Lens
Max Focal Length : 105 mm
Min Focal Length : 24 mm
Focal Units : 1/mm
Max Aperture : 4.2
Min Aperture : 23
Flash Activity : 0
Flash Bits : E-TTL
Focus Continuous : Single
Image Stabilization : On (2)
Zoom Source Width : 0
Zoom Target Width : 0
Manual Flash Output : n/a
Color Tone : Normal
Auto ISO : 100
Measured EV : 7.13
Target Exposure Time : 1
White Balance : Auto
Slow Shutter : None
Shot Number In Continuous Burst : 0
Optical Zoom Code : n/a
Camera Temperature : 47 C
Flash Guide Number : 0
Flash Exposure Compensation : 0
Auto Exposure Bracketing : Off
AEB Bracket Value : 0
Control Mode : n/a
Measured EV 2 : 6.75
Bulb Duration : 0
Camera Type : EOS High-end
Auto Rotate : None
ND Filter : n/a
Canon Image Type : MVI:Canon EOS R
Canon Firmware Version : Firmware Version 1.0.0
Owner Name :
Canon Model ID : EOR R
Thumbnail Image Valid Area : 0 159 15 104
Image Unique ID : 40e5ea9645f0530f01603ab9f9acdbd1
Time Zone : +01:00
Time Zone City : London
Daylight Savings : On
Battery Type : LP-E6N
Bracket Mode : Off
Bracket Value : 0
Bracket Shot Number : 0
Raw Jpg Size : Large
WB Bracket Mode : Off
WB Bracket Value AB : 0
WB Bracket Value GM : 0
Live View Shooting : On
Focus Distance Upper : 0.75 m
Focus Distance Lower : 0.7 m
Flash Exposure Lock : Off
Lens Model : RF24-105mm F4 L IS USM
Internal Serial Number : SK0016329
Exposure Level Increments : 1/3 Stop
ISO Speed Increments : 1/3 Stop
AEB Auto Cancel : On
AEB Sequence : 0,-,+
AEB Shot Count : 7 shots
Safety Shift : Disable
Shutter Speed Range : Manual: Hi 1/8123; Lo 31.9; Auto: Hi 1/4064; Lo 1/8
Aperture Range : Manual: Closed 64; Open 1; Auto: Closed 19; Open 3.7
Same Exposure For New Aperture : Disable
AE Lock Meter Mode After Focus : Evaluative
Dial Direction Tv Av : Normal
Control Ring Rotation : Normal
Focus Ring Rotation : Normal
RF Lens MF Focus Ring Sensitivity: Varies With Rotation Speed
Custom Controls : 29 0 19 0 0 255 255 255 2 0 0 255 255 255 18 0 4 0 53 0 25 0 37 0 13 0 14 2 14 2 29 0 29 0 29 0 29 0 29 0 29 0 29 0 0 0 0 0 90 0 29 0 54 0 78 0 87 0 103 0 39 0 105 0 65535 0 3 5376 3840 0 0 0 0 0 0 0 0 0 0 0 5200 0 0 0 0 0 0 0 0 0 0 7 3 4 31 1 4 0 0 0 1
Customize Dials : 1 0 1 30 31 0 0 0 0 0 0 2 30 31 0 0 0 0 0 0 5 30 31 0 0 0 0 0 0 7 30 31 0 0 0 0 0 0 11 30 31 0 0 0 0 0 0 13 30 31 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 26 23 0 0 31 0 0 0 15 29 28 0 0 0 0 0 0 3840 3840 1 1 0 0 5200 5200 1 1 31 31 3840 3840 1 1 0 0 5200 5200 1 1 0 0
Add Aspect Ratio Info : Off
Default Erase Option : Cancel selected
Shutter Release Without Lens : Disable
Retract Lens On Power Off : Enable
Add IPTC Information : Disable
Tone Curve : Standard
Sharpness : 4
Sharpness Frequency : n/a
Sensor Red Level : 0
Sensor Blue Level : 0
White Balance Red : 0
White Balance Blue : 0
Color Temperature : 5200
Picture Style : Standard
Digital Gain : 0
WB Shift AB : 0
WB Shift GM : 0
Color Space : sRGB
VRD Offset : 0
Sensor Width : 6888
Sensor Height : 4546
Sensor Left Border : 156
Sensor Top Border : 58
Sensor Right Border : 6875
Sensor Bottom Border : 4537
Black Mask Left Border : 0
Black Mask Top Border : 0
Black Mask Right Border : 0
Black Mask Bottom Border : 0
Picture Style User Def : Standard; Standard; Standard
Picture Style PC : None; None; None
Custom Picture Style File Name :
Peripheral Illumination Corr : Off
Auto Lighting Optimizer : Standard
Highlight Tone Priority : Off
Long Exposure Noise Reduction : Off
High ISO Noise Reduction : Standard
HDR : Off
HDR Effect : Natural
User Comment :
Sub Sec Time : 10
Sub Sec Time Original : 10
Sub Sec Time Digitized : 10
Flashpix Version : 0100
Exif Image Width : 160
Exif Image Height : 120
Interoperability Index : THM - DCF thumbnail file
Interoperability Version : 0100
Related Image Width : 3840
Related Image Height : 2160
Focal Plane X Resolution : 110.0412655
Focal Plane Y Resolution : 125.1303441
Focal Plane Resolution Unit : inches
Custom Rendered : Normal
Exposure Mode : Auto
Scene Capture Type : Standard
Serial Number : 013021001771
Lens Info : 24-105mm f/0
Lens Serial Number : 0000000000
GPS Version ID : 2.3.0.0
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Thumbnail Image : (Binary data 21083 bytes, use -b option to extract)
Make : Canon
Camera Model Name : Canon EOS R
User Rating : 0
Movie Header Version : 0
Create Date : 2018:09:05 14:39:16
Modify Date : 2018:09:05 14:39:16
Time Scale : 25000
Duration : 20.60 s
Preferred Rate : 1
Preferred Volume : 100.00%
Preview Time : 0 s
Preview Duration : 0 s
Poster Time : 0 s
Selection Time : 0 s
Selection Duration : 0 s
Current Time : 0 s
Next Track ID : 4
Track Header Version : 0
Track Create Date : 2018:09:05 14:39:16
Track Modify Date : 2018:09:05 14:39:16
Track ID : 1
Track Duration : 20.60 s
Track Layer : 0
Track Volume : 0.00%
Image Width : 3840
Image Height : 2160
Graphics Mode : srcCopy
Op Color : 0 0 0
Compressor ID : avc1
Source Image Width : 3840
Source Image Height : 2160
X Resolution : 72
Y Resolution : 72
Bit Depth : 24
Color Representation : nclx 1 1 1
Video Frame Rate : 25
Balance : 0
Audio Format : twos
Audio Channels : 2
Audio Bits Per Sample : 16
Audio Sample Rate : 48000
Matrix Structure : 1 0 0 0 1 0 0 0 1
Media Header Version : 0
Media Create Date : 2018:09:05 14:39:16
Media Modify Date : 2018:09:05 14:39:16
Media Time Scale : 25000
Media Duration : 20.60 s
Media Language Code : eng
Handler Type : Time Code
Other Format : tmcd
Movie Data Size : 1180121760
Movie Data Offset : 131088
Aperture : 4.0
Avg Bitrate : 458 Mbps
Drive Mode : Continuous Shooting
Flash Type : Built-In Flash
Image Size : 3840x2160
Lens : 24.0 - 105.0 mm
Lens ID : Canon RF 24-105mm F4 L IS USM
Megapixels : 8.3
Red Eye Reduction : Off
Rotation : 0
Scale Factor To 35 mm Equivalent: 1.0
Shooting Mode : Aperture-priority AE
Shutter Curtain Sync : 1st-curtain sync
Shutter Speed : 0
Create Date : 2018:09:05 14:39:17.10+01:00
Date/Time Original : 2018:09:05 14:39:17.10+01:00
Modify Date : 2018:09:05 14:39:17.10+01:00
Circle Of Confusion : 0.031 mm
Depth Of Field : 0.22 m (0.63 - 0.85 m)
Field Of View : 75.0 deg
Focal Length : 24.0 mm (35 mm equivalent: 23.5 mm)
Hyperfocal Distance : 4.69 m
Lens : 24.0 - 105.0 mm (35 mm equivalent: 23.5 - 102.7 mm)
