[Solved] - Litchi Hub heading is disabled
rleiman
Westford, MA
Greetings Everyone,
In Chrome, the Litchi Hub heading slider and also the entry field is disabled. How do I enable it? It's disabled wether I select a POI or don't select one.
Thanks.
Use Firefox. You will then also be able to export your mission as a *.VLM file to simulate in Google Earth like this:
Hi,
I'm using an extension for Chrome that allow me to export the mission as a VLM file which loads in Google Earth.
Do you know why the heading is disabled?
Thanks.
Hi,
Thanks.
I tried it on Chrome, those fields are not disabled on mine.
Here are my settings, perhaps yours are set different:
Reactions: rleiman
Greetings Everyone,
Thanks.
Change the Heading Mode in the settings to "Custom (WD)"
Reactions: rleiman
paul44509
