some guy doing an FCC hack permanent for RC pro Controller
Now I get error install to many times,need waiting
this was from last night and it's still saying same error now
Hi Richard,
I have also no luck.
In the example video the path file is from :
Version Nov 29 2023
The path via google drive which i use is :
Version Nov 27 2023.
Perhaps ??
Ma mise à jour s'est également arrêtée à 87 % - mais le micrologiciel du contrôleur et du drone était sur l'appareil. Après le redémarrage de l'appareil, le nouveau micrologiciel a été demandé. Je pense qu'il n'est accroché qu'à l'écran. J'ai utilisé le DJI Assistant. Mon drone est maintenant à .0700 et le DJI RC à .1000 avec FCC.mon
When I got the error at 87% I restated Rc ran the hack ,it does the hack again then I get to the same point 87% ,rebooted rc tried it will drone and it does work ,I never get the FCC successfull
>>>> HELP <<<<<
Where you get this patch version ( Nov 29-2023 ) i have an older one from 27 Nov 2023 !!
Got it from : Tool Download zip - Google Drive
Looks it don't work .... No FCC.
Please !
Again and Again and AGAIN No FCC.
Also bij using a other new laptop .
Ending with DJ Flij Ap Stopped in screen of the controller.
After that i Have to use FJI assistant to keep the controller running again.
I quit now for better tools.
Are you copying the files from the SD card to the controller as per the instructions video?
which fw have you?
Installed FW is DJI RC V01.03.1000 (Latest). NO FCC
After the first run I get the message below on the controller screen.
Then I run DJIFCC two times more.
By the specified command I copy rm330_0205 xx to SD.
By the specified command delete rm330_0205 xx in DJI RC/upgrade_center/qcom/upgrade package/part-b.
Then as fast as possible copy rm330_0205 xx from SD to : DJI RC/upgrade_center/qcom/upgrade package/part-b.
When I Push the COPY copy button the controller immediately starts to reboot / install.
Then I get the same screen again as below : DJI APP Stopped.....
Then I have to use the DJI assistant tool again, to keep the controller up and running. NO FCC
The DJI assistant tool says I have to upgrade from DJI RC V01.03.0400 to DJI RC V01.03.1000.....Again....
() Thanks for help !
Piet.
I get a bit further
After I have copied and pasted the new file into qcom part b it's on about 8%,it then carries on and says the program will close and carry on in dji assistant it starts at 49% and gets to 87% then fails,I reboot RC and check if FCC mode is working ,in my case No its not its still in CE mode
I never get the FCC patch successfull
d-dot27
