some guy doing an FCC hack permanent for RC pro Controller
Installed FW is DJI RC V01.03.1000 (Latest). NO FCC
After the first run I get the message below on the controller screen.
Then I run DJIFCC two times more.
By the specified command I copy rm330_0205 xx to SD.
By the specified command delete rm330_0205 xx in DJI RC/upgrade_center/qcom/upgrade package/part-b.
Then as fast as possible copy rm330_0205 xx from SD to : DJI RC/upgrade_center/qcom/upgrade package/part-b.
When I Push the COPY copy button the controller immediately starts to reboot / install.
Then I get the same screen again as below : DJI APP Stopped.....
Then I have to use the DJI assistant tool again, to keep the controller up and running. NO FCC
The DJI assistant tool says I have to upgrade from DJI RC V01.03.0400 to DJI RC V01.03.1000.....Again....
() Thanks for help !
Piet.
Piet.
Which fw are you from? Did you have the patch installed on the previous firmware? I currently have the latest fw installed (V01.03.1000). And I'm still using the old June patch, without copying any files.
In the first line i WROTE;
I came from DJI RC V01.03.1000 (Latest). NO FCC
What to do ?
() Richard, try this instructions, i will try it to morrow !
These new instructions should work.
Let me know.
New Instructions below:
After 10 times trying I have LUCK !!!
What i did !
1- Delete all log files in your DJI RC \DJI RC\Internal shared storage and \ SyncResult
2- Mark the folder as save ! See picture below .
3 Run DJIFCC.EXE again and again and again till " FCC INSTALLED SUCCESFULLY " !
TIP : > Navigate to “DJI RC/upgrade_center/qcom/upgrade_package/part_b” so that you are ready for the next part. 9. IMPORTANT: wait for the patch to ask you to quickly replace the file, it says “Please replace the file now!!” It happens after the 1-100% lengthy ‘split file’ process. Watch out for “MSG: get upgreade status: 1%”, because any second now, you’ll have to do the following in very little time. 25 seconds.
Run UPDATE
Wait 2 ours and run DJIFCC.EXE again.
Reboot.
Good luck.
Reactions: dvsls
I’m on .500, what would be the steps to upgrade on RC1? Patch, update via assistant & patch again?
I ended up sending my RC serial number to sincoder via WhatsApp, I then ran the patch and I got to the end stage successfully patched ,I always got the error tried to many times wait
Last week I have successful installed by 3 different controllers the FCC Ap.
The first : was difficult with some errors.
Firmware 01.03.1000 with lost FCC.
Be fast [25 second] for replace files.
The second : Firmware 01.03.1000, FCC never before installed.
Not bad to do, fallow the replacement steps.
The last one : Firmware 01.03.0100 With FCC installed
Verry easy todo.
Run FCC first, than update firmware, wait 2 ours, run FCC gain.
I waited 24hrs and still the hack told me to wait
If you have the same screen as below, i can tel you that the usb port is disconnected.
In that case look if your usb port is connected with the ADB interface. ( is controller usb port ).
Can i Help you remote??
I've done the hack now,it just wouldn't let me do the final part ,everything else went smoothly even deleting and pasting the new file ,
Now I finally have a fcc RC remote
I went through the whole process, getting "FCC patch installed successfully" message. Led off function works when I change the device name, but it still does not use FCC. What am I doing wrong? I believe this should be automatic, but even when I force it, the diagram still shows CE.
Are you copying the file from the SD card to the controller at the end of the process?
Yes, I did that, I replaced the file as the instruction says and it seems like the hack is working fine, because these shortcuts via the device name work, right?
Edit1:
Ok, I am a moron. There is step 15 in the instruction left. I will update this post if this succeeds.
Edit2:
I waited 2h, patched again, the message "FCC patch installed successfully" was seen, but still in Transmission tab it shows CE graph.
To be honest I dont know if the file you copy is for the whole patch or just the fcc part.
Looking at the first screenshot your in FCC mode
mariovaleo
