some guy doing an FCC hack permanent for RC pro Controller
What are u talking about?
Same procedure as far the .300 fw as released.......
0. obtain the latest patch
1. patch the rc
2. update via windows
3. wait two hours
4. repatch the rc
Stop nothing else matter.
No file to delete / replace, no SD.
Do you have the menu to insert your pilot id or it disappeared while in FCC,
with previous version you had to switch to CE ( CC IT ) to have the menu reappear (loosing FCC) .
good morning! i am new to this world. i have the avatar in its latest version 01.05.00.00. How could i hack it to change the dcc? what other hacks can i do?
Rc2 0.0500 update does that patch stil work on latest update ?
It works, but first check if you have ADB open. If so, you can update. Then check if you have the latest version of DJI Fly v. 01.12.08 in the controller (but check in the settings, not by the appearance of the application). If not, restore the controller to factory settings. And then you can upload the FCC hack.
Reactions: TheMavic
Download telegram
This is his username @djifco,he will send you files and instructions you pay 40usd dollars via PayPal for your password
It's round about Chinese New Year, entirely possible he's on a break
Thanks bud
About to update my RC - can I confirm that this is still in FCC?
Correct. But this is only required if you lost your FCC while updating to version 01.03.0400 or higher.
So if I am on firmware V01.00.0700 with fcc on my remote with screen(dji mini 3 pro), then I don't need to do anything special to update to the latest firmware and still keep the FCC, right?
Patched mine this morning, updated via DJI software, patched again after - All good and back on FCC I believe :)
d-dot27
