Special use airspace A292 notice
luizpedro3100
spanish fort - Alabama
Hi all, Iam new Mavic pro 3 pilot. I use it just for hobby and Iam learning about where I am allowed to fly it’s restrictions. After check the app B4Fly I saw a A-292 notice that means “Special use airspace type alert area” low altitude only.
Can I fly there ?
LAT 30.672445
LONG -87.812913
My understanding is it's fine to fly, just be extra vigilant for lots of activity. And I would keep it under 200 feet to be on the safe side.
Check the FAA UAS Map. Type the address in and you will get a map that will give you the approved ceiling heights
If this area is in Spanish Fort, AL. the map doesn't show any restrictions. So, you have the 400' AGL limit. But look yourself to make sure I got the right location
Thank you so much !!!
If this area is in Spanish Fort, AL. the map doesn't show any restrictions. So, you have the 400' AGL limit. But look yourself to make sure I got the right location.
Just to clarify, the ceiling figures in those controlled airspace maps apply only with LAANC approval.
Reactions: luizpedro3100
True (If LAANC is available).
Roel Hopstaken
