I can confirm that DJI Go 4 4.1.22 , for me it removes all latency and pixelation on the
BT-300 with the Mavic Pro and the Platinum
Tested while shooting 4k video at 25 fps, image transmission regular and image transmission rate is now at the maximum 12.36mbps
I removed all the side loaded apps e.g Litchi, UAV forecast, google services for now
via a clean BT-300 install
Then using the
BT-300 browser, I went to apkpure.com and downloaded the following files to the
BT-300
1) DJI GO 4 For drones since P4_v4.1.22_apkpure.com.xapk (164.4 MB) ,
note it is a .XAPK file that will need the Apkpure android app to install it
Download DJI GO 4--For drones since P4 4.1.22 APK | APKPure.com
2) Apkpure android app - APKPure_v2.5.3_apkpure.com.apk (7.9 MB)
Download APKPure latest 2.5.3 Android APK
Instructions for the Apkpure android app, you will need to allow for the "install from unknown sources" in the
BT-300 settings
How to install unknown sources APK to Android
3) Install process on the
BT-300
- Go to "downloads" on the BT-300, install the APK android app
- After install open the app, and hit the 3 lines icon in the top right of the screen to go the next menu
- Select APK/ XAPK Management tab to open
- Then install DJI Go 4 4.1.22 from here
Then have fun flying again
P.S even though all the pano modes are there in the 4.1.22 app and can be selected, they are not working well, the app does not complete the selection of shots, the AC moves into position each time (e.g rotates) but the shots are not taken. Will need to test further
