You are absolutely right. It is a self-help resource, where we help each other. This is the same reason, why I wrote that i do not wish to sound smart, as the info was already there.Isn’t one of the reasons for a forum like this to help each other with info they may know. If I’m wrong I’m sorry for the question.
Here are two additional links outside the forum
1. Air Travel with a Carry-on Drone: Packing tips and TSA battery regulations
2. Traveling with a Drone: The Ultimate Guide to Bringing a Drone on a Plane
Hope this helps.
I took my P4 from Illinois to Oregon on Southwest 737, in a TSA locked waterproof/pressure relief valve case with no problem. Guess they could see there were no batteries in the checked case.As the title says is it okay to pack my Mini in my carry on luggage for a domestic flight?
There both correct. You can ONLY put a battery in checked baggage if it is installed.Is it just me, or do these 2 bullets from #1 contradict each other? Which one is correct?
Think of your drone as a camcoder, laptop or your expensive camara....where do you carry them , the answer is always with you.As the title says is it okay to pack my Mini in my carry on luggage for a domestic flight?
Thank you CyrusNice GSD - he looks to be about 150lbs. Had to put mine down in May. I miss him so much!
Not to revive a dead thread, but took the drone through TSA at Kansas City International (domestic to Vegas) and had zero issues. They didn’t ask anything about it.I took my P4 from Illinois to Oregon on Southwest 737, in a TSA locked waterproof/pressure relief valve case with no problem. Guess they could see there were no batteries in the checked case.
Batteries MUST be carried in the cabin. I have Lipo pouches for my batteries. They didn't even look at them.
