D
Deleted member 114080
Guest
I am not sure if the RTH function of the Spark and Pro are the same but recently I discovered the possibility to change the RTH point from the gps point to a map point.
If you go to the menu, RTH (update home point), you can change to controller position or map position. If you choose map position you can make the Mini to fly to the point you have put in. Basically you can launch the drone change the RTH and drive to the newly entered RTH point without steering anything (Not steering the drone I mean
). (Please note in some country it is not allowed and illegal) Also you can stop the RTH on the way and move RTH point somewhere else or program RTH to the controller. I believe you can still control the camera. So you can fly the full battery time without the need to fly back, as long as you can meet up with the landingspot of the drone. Very nice !
Here's a clip how to do:
Fly safe,
DroneRudy
Fly safe,
DroneRudy
