Tilted Camera on DJI Pro Platinum
Hello,
The camera on my MPP stays tilted on one side approx. 5 to 10 degrees. Even when switched off it stays a little bit on one side and I have to manually center it.
Anyone has had such situation and anyone with good advice is very welcome.
Reactions: old man mavic
have you done a gimbal recalibration ,and check that the gimbal hanger plate has not become detached from the anti drop hook at the back of the plate and the two little lugs at the front,also use a puffer or some canned air to blow the gimbal motors gently to remove any dust or other debris from them
Reactions: CareyL
Thank you for the quick advises. I will try them over the next couple of days when weather is better than raining.
Walt57
