Hey all, I flew the other morning after a large snowfall, and it was quite cold out, so maybe that had something to do with it, but has anyone every seen anything like the weird digital artifact in the photo below? It was about 14 degrees Fahrenheit out, and I was pointing more ore less towards the sun as you can see, but it's definitely not lens flare. There are other photos from that morning with small several pixel wide white spots (when pixel peeping, it's hard to determine if those are actually digital artifacts or something snow covered). Any suggestions/help would be appreciated. This is also the only frame where this crazy purple line happened, and no, its not a power line or anything like that.
