Which of the following things can permanently damage your gimbal?
  • Total voters
    71
Ok here goes. The correct answer was E, all of the above.
A. Leaving the gimbal clamp on - Leaving the gimbal clamp on once, twice or three times when the gimbal is new might not cause any permanent damage, but it really depends on how well the gimbal is glued together, and how strong the motors are. If you leave the gimbal clamp on after the drone has had a dozen flight hours, it might be a very different story. Motors wear, parts overheat, and the current draw to a gimbal that is fighting to level itself while it is restrained is important to note. Gimbal motors dont have a clutch. They are direct drive to the arms, and stressing them out in any way will shorten their lives.
B. Getting one grain of sand in your gimbal motor assembly - Ever get a gimbal motor obstructed error message? It means that something is impeding the motors ability to swing around their axes. Even a cimple little grain of sand can cause an obstructed message, and it's best to listen to it. Examine your gimbal, turn the motors through their axes, feel for any rough spots. If you have been to the beach, and even if you have used a landing pad, sand has a way of getting into the gimbal. If you find some sand in the gimbal. Dont turn the drone on. It wont clear itself. You can use a piece of copy paper to get into the crevices of the gimbal. If the sand is really embedded, computer cleaner compressed air can be used, but that increases the possibility of further embedding the sand deeper into the gimbal.
C. Getting your gimbal wet - Fresh and salt water are your gimbals worst enemies. Yes, even worse than a crash. After a crash you can see the damage, water penetration you often cant. What to do if your bird has taken a bath? Strip it down best you can, and get the water out. Salt water will corrode components in a NY minute if you dont get it out. What do I use? Isopropyl alcohol and a box of Qtips and cotton balls. You can also use electronics contact cleaner, but it stinks to smell it. Really, every single piece of the drone that got wet needs to be looked at. In the gimbal, the most important part is the gimbal PCB that sits atop the gimbal. During one repair, I just couldn't get the gimbal to calibrate. I took off the gimbal PCB, and the bottom side was covered in salt. The owner didnt tell me he was flying near the beach. New board cured it.
D. Flying too much in sport mode - Did you know that 75% of the repairs that I get in are in sport mode? Sport mode = no sensors, and not obstacle avoidance. What affect does sport mode have on your gimbal? Sport mode causes the gimbal alot of stress. Fast starts, fast stops, spins, max speed flight will make your gimbal work very hard to keep level. It is gyro stabilized, and wants to keep itself level. By causing it to have to correct itself every second that you make an abrupt maneuver, you are stressing it out. When a gimbal is new, it might be able to handle it. When its old, you might just smoke it. If youre gonna fly in sport mode, maybe get a Spark. They only have 2 axis gimbals and are alot hardier than the Mavics. Also, on the M2, the M2P has a $600 gimbal on it. Do you want to have to replace it? I dont think so.
One more thing, try not to yaw and spin around too quickly. The yaw motor is very not very strong, and has limited travel. If you do a quick 360, the yaw motor is going to try and catch up as best it can. If you fly like a photographer, you will never stress your gimbal out. Slow and steady.
Aight, for those of you who stayed awake long enough to read the end of this diatribe of what not to do, I salute, you. For those that didnt, you have my address.
Peace.
Rob
Thanks Rob! Less than 10 hours on mine and will baby that thing for now on. As you pointed out, its a camera, not a hot wheel...
Reactions: Former Member
Based on everything that you have ever posted on this forum, I would trust you to fly any of my drones. You know how to take care of your baby.
Reactions: AMann
Peace.
Rob
Not going to lie, I’ve flown in sports mode and did the spin around too quickly a couple times. I know now to never do that. I’ve got about 20-25 hours on my Mavic 2. Is there any way to tell if I’ve done any permanent damage to my gimbal?
It's your drone, so you can do anything you want, but theres just a risk/reward to doing it. Telltale signs of gimbal damage are squeals, burning smell, horizon that just wont level out, gimbal motor overloads, gimbal obstructed, etc. The M2 has a big clunky gimbal on it. The motors are strong but the gyros are always trying to keep that volvo sized lens straight and level. Gimbal motors are really not a maintenance item unless you do extreme flying on a regular basis. Yes the M2 can do 40mph, but the gimbal wont be happy if you do it all the time.
Reactions: Ynksfan27
The problem with sports mode as it relates to your gimbal is that the rapid starting and stopping of your drone creates extra work for your gimbal gyros to catch up with the rest of the drone to stabilize the gimbal. The gimbal really wasnt made to be jerked around for either photography or for flight. The gimbals motors can overheat of sudden starting and stopping occur, they simply cant overcome all the g forces and motion being subjected to them.
2 moves that I would never do with my drone are full speed yawing, and full speed braking. Full speed yawing makes the gimbal yaw motor work harder to catch up with the yaw motion of the drone, and can fry the motor. High speed braking, "snake rearing", is also bad because it forces the gimbal pitch motor to its downward limit to try and hold the angle. This will hurt your gimbal, and possibly break a ribbon cable.
safe to say if it was mounted on the hood or roof of a car, it could stress out the gimbal too much? how fast do you estimate before it took on damage? 35mph?
Thanks for this info
OldGitRay
