Why does an IMU need to warm up?
jimheid
This is a "I'm curious to know what's going on under the hood" question, not a problem report.
I'm writing some stuff about the Mavic Pro and would love to include some technical details on what's happening during IMU warmup. Does the IMU actually need to be at a prescribed temperature to work reliably? Does it have a tiny heater inside? A set of vacuum tubes, perhaps? (Kidding about that last part.)
Thanks in advance to anyone willing to share some geeky details.
I'm not an electronics engineer but yes, I believe that IMUs do have a temperature range within which they function most accurately.
From Wikipedia, Inertial measurement unit - Wikipedia "- environment sensitivity: mainly sensitivity to thermal gradients and accelerations."
There wouldn't need to be a heater of any kind though, as even solid state electronics warm naturally when functioning. Thus, the need for a fan on the Mavic to carry away the excess heat.
Others can give more precise details, or correct me if I am wrong, but this is the way I understand it.
Reactions: jimheid
My understanding from looking at csview is that, looking at the IMU temperature parameter which is recorded, it's very tightly controlled during operation so the output must be quite highly temperature dependent. I also don't know the physical reason for the temperature dependency and would be interested to know.
Reactions: jimheid
Some accelerometers are based on a heated gas in a chamber resulting in the warmest gas being at the top (v. gravity). Change in speed causes the mass of heated air to deflect and that is measured. (I don't know if that is what is in the Mavic or if such is practical in an airborne vehicle)
Many (most) accelerometers are a micromachined arm that deflects during acceleration and since the electronics will warm up at some point, the measurement is calibrated to work best at their "warm" point or higher. Newer MEMS do not need to be pre-heated. Not sure if gyro sensors need to be pre-heated.
(If you have an iPhone there is an app called Sensor Log where you can observe the accelerometers and gyros in the iPhone. You can even output them via WiFi IP to a local network - telnet them and watch; record, etc.)
Thanks VERY much! These are exactly the kind of details I was hoping for. So fascinating that so much precision can be built into such a tiny package. (And I'm referring to the MEMS as well as the Mavic as a whole here!)
In any case, to me what is more important than waiting for the IMU is waiting for GPS to have a good position before starting the motors. By the time that happens the IMU is long past warmed up.
I'd disagree. The aircraft can flown without a GPS lock. The aircraft will basically not fly without the IMU working.
For what it's worth, if you start up everything and do your preflight check list, the Mavic will be ready. 3 to 5 minutes to make sure you are ready shouldn't hurt you.
Very much agreed! I like to say that when I'm on the ground, I've got gravity exactly where I want it. But as soon as I take off, that equation flips. I'm very willing to take a few minutes to make sure I'm ready to go up against gravity.
Mamanov Ramazan
