Haha!! Hey guys yea MacIak is for real.
Pity
@Shannon does not reply in his defence.
I got an update for the use of FPVLR boob antenna with the dual booster by Sunhans.
I believe Soundwave is to stay. Why? Just to compare results with my previous post benchmarks. I ran in to a fellow droner with a
P4 using unboosted panel antenna's and formed up for a flight. The headwind component was a killer today (max 30 km/h into wind, no sport mode and no obst avoidance on) could not make it to point 4 without risking a ditch.( reminder: CE region)
No1: full signal
No2: full signal, HD flashing.
The phantom had triggered RTH around 1500m!
No3: had to climb again ( yes, dronepolice) to 150m this time to keep LoS. Full signal, tx flashed a bit. After this for me enough evidence this thing performs really well. Went back after this.
Compared to tx only boost it clearly improves downlink too. Signals were solid and stayed solid. Overall slight better performance than tx only boost. Keeping LoS is a pain around here at distance.
Conclusion: the bigass sunhans like its little golden bro WILL perform kickass with a good antenna.
I will also hook it up to the Nanosync when i can find a way to mount it properly but need a spare booster in case the Nano turns out to be a booster- killer.
I still need to make 1 more rg58 to replace the thin cable (oh, this cable is wonderful quality!!) but ran out of correct connector type.
IMPORTANT NOTE: do not use connector adapters as
@CyberNate also mentioned before if possible. They WILL reduce your signal significantly (i ran into this several times and i did not use cheap ones)!
View attachment 13053View attachment 13054
Edit: still did not charge the 3s 1300mAh lipo. After more than 2 hours of flight all 3 cells read 4.15v!! The big booster uses slightly more than the little one but still very little drain.
