400 FW
phantomi
Hi. I received a new MP aircraft only and came with 400 FW. Because I was in the 700 in my crashed bird with app updated to the latest was wondering if I can maintain 400 FW with the new bird and use the latest app FW w/o problems. Thanks.
It won't be a problem using the older firmware with the latest app. You won't get the new Quickshot features but everything else should operate normally.
Reactions: phantomi
Thanks. I'm using it and everything is operating normally. I want to keep 400 for a while because have read good things about it. Also have note the new Quickshot feature and have to read more about it. Also the FixedWing mode could be a factor to move on. Thanks again.
Why not upgrade with a modded version of 1.4.000? As others have said - best of both worlds.
How to rollback Mavic firmware
Reactions: phantomi
I would guess he means modified version of FW. When I looked at the link, it appears they are talking about hacking (modifying) the FW. Which is different then just rolling FW back to earlier version. I am sure DJI would look at this as voiding your warranty, if you had a problem and had to send it in.
Also, when you say app FW, do you mean app version. To me and most here, FW only means the Firm Ware on the MP/RC/Battery. The GO4 app, if that is the one you are using, has different version. iOS version can not be rolled back, but Android version can be rolled back.
Also, It would be helpful if you gave us more information as to what device you are using, what software, etc. Otherwise we are just grabbing at straws and spinning our wheels.
The mavic is made up of several different modules; camera, gimbal, esc, fc, core, battery
Each part has its own fw, its not really modifying as assistant 2 has each individual fw package separate and there is a feature in assistant 2 to load individual firmware packages to the Mavic
The bin files are to keep the packages together and make it easy to load with a custom tool (DUMLdore)
Hi,
Would it be possible to have an exact list of modules necessary for fw v01.04.0000, that for RC and AC.?
Thanks, regards.
-= Guy =-
Firmware modules starting from .400 (compiled by others):
400 to 500:
100 - P4P, P4, i2, Mavic Camera Upgrade
101 - P4, Mavic Camera Loader Upgrade
306 - P4P, P4, i2 FlyCtrl, Spark, Mavic FC APP Upgrade
400 - P4P, P4, Spark, Mavic Gimbal Upgrade
801 - Android recovery ROM?
805 - upgrade.zip (calibration for VPS?)
905 - added
500 to 550:
550 to 600:
100ca02 - ? Camera profiles?
101 - ca02
907 - Mavic modem/arm/dsp/gnd/uav "upgrade file" (unencrypted)
600 to 700:
700 to 800:
101ca02
802 - Modvidius ma2155 VPU firmware, "DJI_IMX377" (CMOS image sensor) firmware, Veri Silicon Hantaro Video IP encoder/decoder ?
905 - NFZ Database (nfz.db and bfz.sig)
1100 - i2 Battery_0, P4, Spark, Mavic Battery Upgrade
800 to 810:
800 to 900:
100ca02 -
101 - ca02
900 to v1.03.1000
101ca02 -
305 - P4, i2 FlyCtrl_Loader, Spark, Mavic FC Loader Upgrade
803 - ?
804 - "System Initialized" ?
added 1200es02
1200 to 1203 - ESC upgrades
v1.03.1000 to v1.04.0000
101es02 -
1200es02 - ESC profile?
Reactions: gdlmus
IOS can be rolled back
@lisadoc
Ca02 & es02 are for the same module as without but different hardware
So 100 &101 old hw, 100 ca02 & 101 ca02 new hw
1200 es02 platinum esc hw
As you can see from gdlmus's picture from factory they chuck everything on the mavic as 60* and 280* are RC & goggle fw, looks like 3 hw variants of the controller
I'm looking for help. I have read several posts. You seem like you have an understanding. I realy have no understanding about what I'm asking. What needs to be updated? Firmware, yes ok. Do controller need to be updated or anything else? If so how? Like I said, I'm at a loss here. If you think you can help but it would be just to much to type. Say so and I will give you my phone number.
RRB
