BobDoLe
- Joined
- Oct 2, 2018
- Messages
- 196
- Reactions
- 127
- Age
- 98
That's what they want you to thinkIt's not the Pitutary Gland you need to be worried about
It's the Pineal..
It's the Pineal..
I did read that after I posted lol . So how good is it ? And Would you buy it again ? Thanks bro oh here is a pic of a run I did this with maxx extremeThanks m8
Appreciate you sharing your collection there
I went with the Alientech Pro as you probably read.
Post a review if you do get one setup.
I'd be interested to see how it performs against the res
Yup. I also tried different channels under 2.4. The whips rattle a bit so I'm wondering if maybe there's something wrong with them.Mavic 2 is dual band. The Titan switch is designed for 2.4ghz.
Obviously you chose the 2.4 setting in GO?
earlier in this thread, i also mentioned i had mediocre results with the giant titan antennas. $6 Alfa ARS-NT5B (2.4ghz and 5.8ghz dual band) work better... and actually on my mavic 2 pro, i just tried them un-amped and they work almost as good as the stock antenna on 5.8ghz. I was pleasantly surprised range was approx 5% short of the original dji controller antennas through interference.Just tried my titan switch system boosted with the 5dbi whips. I'm getting pretty mediocre results - I can barely tell the difference between the stock controller and the boosted with the 5dbis. I also bought additional 9dbi whips, yet the 9dbis are too big for me to realistically take many places (going to NZ). I'm seriously hoping I can return the set up and have the controller returned back to its default state. The modded controllers without the whips attached no longer fit in the fly more bag. Needless to say super disappointed with the performance.
i've got the alientech as well as a titan switch.
the alientech is the clear winner out of the two of them on performance, but the portability is also a huge bonus. on top of that, you can just carry around an extra set of 18650 batteries as opposed to worrying about recharging the unit itself.
the titan switch with the whip antennas they sell performed worse than the stock controller with FCC 1.5w boost mod (as in no hardware mods).
the titan switch with the panel was also disappointing. HOWEVER, it works GREAT with the new Video Aerial Systems 2.4ghz Crosshair Xtreme "patch killer" as the signal really penetrates with a nice wide beam.
even then... at longer ranges the alientech will go even further, albeit with a super narrow beam that is a little challenging to keep centered on the aircraft. the fix for that is using the compass/radar on the dji go app, but with my phones the remote control hall effect sticks interfere with my phone's compass always.
one design issue:
the weight of alientech unit is entirely supported by the QMA quick release and after putting about 500 miles of flight on it, i'm noticing some wear which was causing the left side to loosen up a little. i ended up replacing it with a cable off my mavic air's alientech pro 5.8G.
alientech sells replacements and a pair of these sell for $20 + $10 shipping. it is a just a male qma to male qma with one side being threaded that you could get elsewhere, but alientech's price seems to be the lowest i've been able to find for this connector.
