- Joined
- Jan 23, 2019
- Messages
- 6
- Reactions
- 4
Do they tend to stay away from drones? I saw one go right in front of me on my last flight. Also, are bats pretty good at avoiding them?
i like your use of the word raptors we tend to forget that birds are direct decendents of dinos and a lot of there behaviour is as a result of having to survive in hostile enviroments i guess we will just have to get used to these attacks and try to share the airspace with them the best we canMany birds can get aggressive towards a drone, especially when they are nesting and protecting young, not just the larger raptors. Always a good idea to try and avoid flying in nesting sites during the spring.
The best thing you can do if you get mobbed by a bird is do a quick vertical ascent. At the very least this will buy you some space to manouver as they will not be able to climb as fast, but it's also a sign of aggression that may might deter some birds right there and then. If they keep coming, climb and run repeatedly until you clear the area or they give up.
Agree with the 'climb' recommendation, because a bird will 'know' that the Mavic is 'stronger' and more agile than it is, if the Mavic can out-climb it ... Generally, any sort of predatory bird doesn't take risks, because it knows that if it hurts itself, it can't feed. So a show of strength should be enough to get by ... Conversely, if you dive the Mavic, you'll look like lunch!Many birds can get aggressive towards a drone, especially when they are nesting and protecting young, not just the larger raptors. Always a good idea to try and avoid flying in nesting sites during the spring.
Seagulls are the worst! They get very territorial. On many occasionas 1 seagull will see the drone, start sqauking and call his friends, before you know it you have hundreads of them swarming the area. When your hovering the dummies will dive down at the drone and turn away at the last second. I've been hit by seagull **** a couple of times. Best thing to do is fly up and away, once they don't see the drone they quickly disburse. I think it's a small brain issue. Whenever hawks see the drone, they'll usually circle for a couple of minutes and then decide it's not prey and move on (obviouly bigger brain and smarter).
This is exactly what happened to me when I was on vacation in Portugal. I was trying to fly near the coastal cliffs and caves near Lagos and the seagulls seemed to come from nowhere and surrounded my MPP, sport mode and straight back. Tried a second time same result, I gave up after that.Seagulls are the worst! They get very territorial. On many occasionas 1 seagull will see the drone, start sqauking and call his friends, before you know it you have hundreads of them swarming the area. When your hovering the dummies will dive down at the drone and turn away at the last second. I've been hit by seagull **** a couple of times. Best thing to do is fly up and away, once they don't see the drone they quickly disburse. I think it's a small brain issue. Whenever hawks see the drone, they'll usually circle for a couple of minutes and then decide it's not prey and move on (obviouly bigger brain and smarter).
Immediate ascent is the correct action, but it should be followed by an almost immediate landing if possible. Then get the hell outta there cause sooner or later you have to land and protect your bird anyhoo. Some of those Tweety Pies are large enough not to give a **** and take your bird home to their babies!Many birds can get aggressive towards a drone, especially when they are nesting and protecting young, not just the larger raptors. Always a good idea to try and avoid flying in nesting sites during the spring.
